L3830GST won't turn over after working fine yesterday
   / L3830GST won't turn over after working fine yesterday #11
Like others I would check the safety switches. May not be bad but could need adjusting. I have a different tractor but I was having an issue and it turned out to be the safety switch on my gear shift was not detecting I was in neutral. Found that if I put a little pressure on the lever in one direction then I could start. Ended up being a simple adjustment to the switch position. Seems that anything that's adjustable can vibrate out of adjustment given enough time.
Does anyone have a list of the safety switches that ARE ON the L3830GST and where they are located? That would be a great help in tracking down this issue. Thanks.
   / L3830GST won't turn over after working fine yesterday #13
Hey tracecom -- what is an ECU ? Not familiar with that acronym. I'm a retired EE so usually know but that does not ring a bell.
More info coming soon! (A55851)
More info coming...
Hook & Cable Strap (A59076)
Hook & Cable Strap...
2004 DCT PUMP TRAILER (A58214)
2004 DCT PUMP...
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
CATERPILLAR 305CR EXCAVATOR (A52709)
CATERPILLAR 305CR...
