L3830 bad front wheel bearing?
   / L3830 bad front wheel bearing? #1
PapaPerk
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
Hello,
My Kubota L3830 is leaking oil from the front right axle hub. I lifted tractor with loader and front wheel appears to have some play. I'm assuming bad wheel bearing.
Has anyone had similar problems? My tractor has around 720 hours and is a 2004 model. It does quite a lot of loader work.
I'm considering replacing bearings myself. Any tips or pointers? Is it a DIY project?
Thanks for the help
   / L3830 bad front wheel bearing? #2
I have done a few Kubota and deeres common problem of front seals leaking easy as long as you have basic mechanical skill and tools. the outer seal is super easy the one where the spindle turns is a little harder, if you have to do that one change the bottom plug don't try to reuse, its cheap, the seals aren't.
   / L3830 bad front wheel bearing? #3
I went through the front end on our old L3750/ Not too hard, just standard mechanic work.
What killed mine, was too much FEL work without enough weight on the 3 pt hitch.
Thanks for the responses guys. Yeah I used to run without much ballast. I made a 3 point ballast hitch awhile back. So that should help some. I still feel the Kubota front end is a bit weak compared to their larger tractors.
But I can't complain! Lol
   / L3830 bad front wheel bearing? #5
With all the tractors that we work on we have not seen any trends of one being any weaker then the other with normal use. We do notice differences in longevity as to the type of use and how tractors are ballasted. We do like three point hitch ballast the best realizing that it can't always be used but it does save a lot of wear on the front end over just loading tires. For some we like to see both if possible but the three point is the best.
   / L3830 bad front wheel bearing? #6
There's some guidance here on changing front axle seals. Many models have very similar construction. If oil has been leaking out, there's a possibility water has been leaking in, which can lead to bearing failure.
(3) STEEL CARTS W/ WHEELS (A51248)
(3) STEEL CARTS W/...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
RV Hitch (A50121)
RV Hitch (A50121)
Kioti DK 35, 4WD, Quick Attach Loader with Bucket  (A52384)
Kioti DK 35, 4WD...
