L3800 wont start
/ L3800 wont start #1
toddbiss
Bronze Member
Enfield, NH
2011 Kioti CK20hst
Pretty sure it was run out of fuel. Tried the bleeder near the fuel filter and cracked the injectors. Any other tips?
/ L3800 wont start #2
Need more information... cranks but doesn't kick over? how long did you crank it after you open the bleeder valve?? Same ?? with injectors... Can you get fuel to flow to the filter?
/ L3800 wont start
Cranks over and tries to go. Fuel filter is full.
/ L3800 wont start #4
There is a small bleeder screw/lever near the injection pump.Crack that open and get fuel to come out, close it off and keep cranking...Mine took about 30 seconds of cranking to fire up when I had to do it.
/ L3800 wont start #5
Just turn the bleeder and set a fuel at half throttle and crank till it starts then close the bleeder........
/ L3800 wont start #6
I had to crack the lines at the injectors on my L3200 after my father-in-law got plastic in the fuel tank which starved it.
