L3800 leaking rear end oil
   / L3800 leaking rear end oil #1
F2036
My L3800 4x4 HST with 77 hours on the meter has started leaking oil. It is comming from the the seal between the left (range lever side) axel assembly and the center section of the rear end. Have any of you guys had this problem? What did it take to fix it? Is there a flat rate price on fixing this at the dealers shop? I'm not sure I want to tackle this myself, if it were an older tractor I would give it a try.
Any advice or thoughts would be appreciated.
   / L3800 leaking rear end oil #2
is your tractor under warrenty yet i never had the seal go out on the case i had 11k hrs on it
   / L3800 leaking rear end oil #3
I've never heard of this problem. You should still be under warranty...
   / L3800 leaking rear end oil #4
L3800,s have only been out a few years. Deffinatally should still be under warranty
Well, I jumped to soon on this one. I had a hyd hose that had a pin hole leak and was spraying hyd oil here and there. Sure glad that was the problem and nothing more serious.
   / L3800 leaking rear end oil #6
Great news. Thanks for the update.
2003 Polaris Sportsman 700 Twin (A51573)
2003 Polaris...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
HARDEE RD72M LOT NUMBER 154 (A53084)
HARDEE RD72M LOT...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
