L3800 coolant leak @ 75 hrs - check those clamps
   / L3800 coolant leak @ 75 hrs - check those clamps #1
kallnojoy
KY
Kubota L3800
Discovered a bit of coolant under the tractor last weekend.
Apparently happened after parking it.
Poked around a bit looking for the source and discovered this:
Tractor is less than 100 hrs and it's the unmolested stock hose & clamp - which besides being installed askew was also under torqued.
The clamp looked like it was seated properly when viewed from the accessible/front of the motor, but snapping a pic from behind showed the cant.
Glad it was something trivial and a quick fix to adjust it down, snug it up and top off the coolant, but yet another little thing to add to the mental check-list.
   / L3800 coolant leak @ 75 hrs - check those clamps #2
My BX did the same thing on the top radiator hose. I kept smelling antifreeze. The top hose was just a little wet. Alot of times a clamp will need retourqed after it has been on for a short period of time, I guess that is why cars have the spring loaded clamps.
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2 Chains and 4 Binders (A51573)
2 Chains and 4...
