3-Point Hitch L3750 debris in hydraulics?
   / L3750 debris in hydraulics? #1
tractorsam
New Germany, NS
Kioti DK45SE HST Cab
A friend of a neighbour uses an L3750 with a hydraulic shuttle in their Christmas tree operation. Yesterday they asked me to have a look at it because it wouldn't move. After having a look we also discovered the 3 point was not working, the power steering was. We ended up trying a new hydraulic filter on it and discovered the suction for hydraulic filter plugged with fingernail sized pieces of what looked like thin paper gasket. After cleaning this out the tractor now works as it should. Any ideas what the material may be and if there's another problem causing this? Thank you, Sam
Does this mean the brakes should be replaced or is this normal? Thanks, Sam
Quick Attach Pallet Forks (A47384)
Quick Attach...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
UNUSED CFG INDUSTRIAL STSD10 QUICK ATTACH SEEDER (A51244)
UNUSED CFG...
Toro Z Master Mower (A50324)
Toro Z Master...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
