Snow L3710 Mid-PTO Operation
   / L3710 Mid-PTO Operation #1
boozaro
Peshastin, WA
Kubota L3710
New member here. So I recently purchased a 2002 Kubota L3710 with a front mounted snow blower which uses the mid-PTO.
What is the correct method/process for engaging the mid-PTO?
How do I determine if I do or don't have independent PTO type?
I have searched the threads, but I am still not very clear.
I really appreciate the help.
Scott
Did I post this question in the wrong place or should I look elsewhere for the answer? As I mentioned, I'm new, so I don't want to screw up the flow.
Thanks.
Scott
   / L3710 Mid-PTO Operation #3
The mid mount PTO on my Branson 2400 is lever operated indicating that gears have to slide to get it to function. The clutch is necessary to engage (not necessary to disengage) as a result. The lever is marked for the MM rpm or 540/960 selection for the rear.
My 6530 is Independent and the engagement is via electrical solenoid, selector switch operated, meaning that you can engage/disengage it whenever you choose with no clutch action. I do have a selection lever for which of the 3 speeds I want to use and that is to be done with the clutch engaged as you are moving gears. This tractor does not have a MM pto shaft. On any PTO it's best to do the engagement at low rpms to reduce the shock load on the gear train.
Of the 3 PTO types: Transmission, Live, or Independent, Independent is the handiest for most applications followed by Live which is a dual clutch disc type setup on older tractors whereby the clutch pedal position determines whether you have the PTO clutch engaged only, or if PTO lever is on, PTO and ground drive.....this is especially useful in line post hole digging. On my 6530 I have a Live position on the PTO selector whereby activating the clutch pedal, I can interrupt the PTO rotation, whereby in the Independent position it is independent of everything but engine rpms.
   / L3710 Mid-PTO Operation #4
I'll qualify my answer by saying I don't have a L3010, but have a L3130 and L4740. Both of these tractors require both the mid and rear PTO to be engaged to power front implements from the mid PTO. Typically engage mid PTO and then the rear.
Mid PTO's require gears to be meshed like in a manual transmission and the rear typically has it's own internal clutch (gears are already engaged and thus no meshing like the mid PTO).
Enjoy the new ride!
FYI... Sometimes it is best to ask Kubota specific questions in the Kubota section.
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2017 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2017 Elgin Broom...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2013 John Deere 350G LC Excavator (A59213)
2013 John Deere...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
