L3710 Front Axle Bevel Gear Case removal
   / L3710 Front Axle Bevel Gear Case removal #1
Woodsman123
Mohawk Valley NY
Kubota L3710 GST
Hi all,
I have a leak it appears at the bottom of the case of my right front bevel gear case. Also when I had previously changed the gear oil I noticed some metal shavings in the oil. I found this post to be great info but I was wondering if I could just remove the whole bevel gear case from the Axle case and bring it to the dealer and have them disassemble it and diagnose what needs to be repaired. Thanks!
   / L3710 Front Axle Bevel Gear Case removal #2
Is there noise or visible looseness? If not but you're concerned about the filings, taking the bevel case off the axle may not be useful. A technician would likely prefer to inspect the tractor whole, diagnosing it with and without load etc. If the only present symptom is an oil leak, apparently just at the bottom, the easiest cure is to pry out the C plastic plug and tap in a new one.
Thanks! I'll try to just replace the plug and go from there.
2002 Volvo Tandem Axle Road Tractor (A47384)
2002 Volvo Tandem...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
2013 John Deere 2210 Accudepth Field Cultivator (A52349)
2013 John Deere...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
John Deere 2355 (A50120)
John Deere 2355...
