L3700 turn buckles
   / L3700 turn buckles #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
Does anyone happen to know what other model tractors slide arms (for the 3pt hitch adjustment) would fit the L3700 and replace the outside turn buckles. The part numbers would be a big help if someone has them also.
Thank you, I am getting tired to spinning the turn buckles several times a day to adjust my implements
   / L3700 turn buckles #2
If you do a search on turnbuckles you should be able to get a part number. I replaced mine on my L 3400 this summer. The L 4400 comes standard with the slide bar type and it is an option for the 2800 & 3400. I can't remember the part number but it is called a stabilization kit the cost was around $165.00. I know I posted the part number. Hope this helps.
Thank you, I looked under L3700 so will help.
Thanks!
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
New Wolverine Dingo Bucket Broom (A50774)
New Wolverine...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
