L3700 SU Starting issues
/ L3700 SU Starting issues #1
Tomtint
Elite Member
Boston
L3700SU
So over the past few years, I would have an intermittent starting problem with the L3700 SU. After reading all the typical problems that have happened with the L3400 ( basically the same tractor ). In many cases the issue was the safety switch below the steering column. So over the past few years I have replaced it a couple times. Well.. It wouldn't turn over again last week and again this past weekend. I had an extra safety switch and plugged it in..Still no start. Plenty of power. Solenoid clicks..Just no start. Tapped the starter with a hammer....bang...fires up. Starter is now ordered from my local dealer..about 150.00.
/ L3700 SU Starting issues #2
I don't know that replacing the starter is all that justified. I have 3 B2150s and one BX2200. One of the B2150's has around 1750 hrs on it and it has exactly the disease you describe. I have had to reach in with a socket extension rod and tap the starter with a light hammer ping on the rod reaching the starter probably 5 times over the last couple of years. Maybe have to do that once out of 50 starts ? I had the BX2200 do it twice but far less often and much lower hours tractor. I have not felt a need to replace the starter yet.
Other posts on TBN have mentioned this. Some think it is wear in the starter. Some think it is a random thing where if the starter quits in exactly the right rotation position the last time you used it it sticks. Who knows.
2019 Toro Groundsmaster 7200 72in. Zero Turn Commercial Mower (A61572)
2019 Toro...
2015 Hitachi ZX210LC Hydraulic Excavator (A61572)
2015 Hitachi...
Generator Motor & Wheel Spacers (A64119)
Generator Motor &...
INSPECTION (A65563)
INSPECTION (A65563)
UNUSED WOLVERINE BUCKET (A64281)
UNUSED WOLVERINE...
2017 Jeep Renegade SUV (A61574)
2017 Jeep Renegade...
