L3700 rear remote questions
   / L3700 rear remote questions #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I would like to install rear remotes on my L3700. I would like to be able to:
1) adjust the up and down pitch of a rear blade
2) Adjust the up and down angle (one side up a bit more than the other to cut road crowns)
3) possibly angle the blade left to right
What the heck do I need to buy -I am guessing I need 3 spool valve but have no idea the type. what hosed and connections (I am wanting quick attach like the loader of course)
I am not concerned with fabricating mounts for this setup, that is the easy part! Is there some ebay stuff out there or a website that is reasonable.
thanks - I no nothing about hydraulics but can wrench about anything. This seems like a fairly easy project to "build" once I understand the parts and how they work/connect.
Thanks
   / L3700 rear remote questions #2
Teg did a nice write up on his L2800 doing this, In fact I think the link is in his signature line. You might do a search for it.
James K0UA
   / L3700 rear remote questions #4
Little late to the party :cool2::dance1::drink: Guess I missed it the first time around. :p Code54, it took me several readings of other people's projects to understand what's going on with hydraulics. Just keep asking questions, will this valve work for me? or why the heck did you do this?
Some of what I bought in my (signature) thread is not on Surplus Center... also, I would have changed the hose ends to be able to screw straight into the valve spool. Anyway, good luck let us know if you need help. :thumbsup:
   / L3700 rear remote questions #5
... I would have changed the hose ends to be able to screw straight into the valve spool. Anyway, good luck let us know if you need help. :thumbsup:
I learned this too doing mine, you really only need one swivel end per hose in most situations, the other end can often be an NPT thread. Less costly since it's simpler and there's no adapter to go from NPT to 37 degree JIC in my case.
Sean
Thanks for the extra info! Had a little change in my plans. I was thinking hard about adding rear remotes to the 3700 but I was still thinking I was underpowered in a lot of ways. My wife and I were talking and she mentioned that maybe a bigger tractor was a better idea.... So we started looking, and I called everyone for 200 miles and ended up finding a new MX5100 with rear remotes already installed, a LOT stronger loader, and a bunch of other features for a good price so we are pulling the trigger and moving up in size.
But, as always, I appreciate everyones input and ideas! Thank you!
   / L3700 rear remote questions #7
...My wife and I were talking and she mentioned that maybe a bigger tractor was a better idea...
You have a good wife :thumbsup: she's a keeper :D
Did I miss the photos of the new tractor on another thread ??? :laughing: (hint, hint)
   / L3700 rear remote questions #8
If you dont mind, since you know what the jerky 3pt is all about. please check out the MX5100 and report back if it is nice and smooth or jerky or somewhere in between.. tnx
James K0UA
   / L3700 rear remote questions #9
Well, you will still need that top and tilt kit. email me at Fit Rite for all the details if you are interested . ;)
I will get photos soon a it arrives. They are expecting to deliver it next week so once it is here I will post something. (I can't wait, I'm like a kid on Xmas)
I will also check the rear hitch and make sure it is smooth as expected and let you know what I find!
2005 MACK GRANITE GU713 DAY CAB (A51219)
2005 MACK GRANITE...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
