L3700 Bottom Plow
/ L3700 Bottom Plow #21
Larry Caldwell said:
You can use what we used to call a drag or a go-devil. Have you ever seen a stone boat? You can also chain some logs together to break up the clods, sort of in a harrow configuration with the logs a foot or so apart. They need to be at least 8", 12" is better, and fairly straight. You don't pull them long ways, you pull them cross ways.
It shouldn't be hard to find a cheap harrow. Just about every farm has a couple in the weeds. Maybe you could borrow a disc. I use an old John Deere pull type cover-crop disc because it does a better job of cultivating than any 3-point disc I have ever used.
See if you can find directions for that plow. It used to have a trip rope that raised the shares when it was time to turn a corner. After the turn, another pull on the rope dropped the shares back into the ground. It also had coulters that cut the sod in front of the shares that may be missing. It will still work without the coulters, but not as efficiently or cleanly.
If you haven't plowed before, you open up a couple parallel lands by plowing long ways through the field and back, casting the dirt to cover in the center. Leave more than 1/2 of the width of the field between the lands. Plow out each land until you reach the fence line, and leave a dead furrow along the fence line. Then plow out the space between the two lands (remember, MORE than half the width of the field between them), leaving a dead furrow in the center of the field. Then plow out the headlands where you turned around for each furrow. If you have drainage problems, a dead furrow will make a serviceable ditch to drain winter wet spots. The next year you start with one wheel in the dead furrow and reverse your lands and furrows to put the dirt back where you got it.
A disc won't move dirt sideways like a plow will. You can do contour farming with a plow and it will hold up as you work up your seed bed.
thanks Larry. there is enough in your post for me to get it done. I found a name plate on the plow and it's a Dearborn 10-8. both coulters missing but I pulled a few rows last night before dark and it looked promising. need to make some adjustments now that I know the model.
/ L3700 Bottom Plow #22
To correctly measure a plow, you need to measure from the outside of one main beam to the inside of the other main beam. A used plow could have any size point point put on it over the years?? Ken Sweet
/ L3700 Bottom Plow #23
Love that plow. You sure plow a straight furrow. Ken Sweet
Thanks Ken.
It's my favorite toy, er, implement! :)
I put a lot of time and money into getting the plow back into working shape. It was worn well beyond normal limits getting into the parts that weren't supposed to wear. (like the frog)
I appreciate the compliment about my furrow. I pretty much let the tractor go with not much input from me. Probably wouldn't have been so straight if I had driven it a bit more.
As far as the OP's tractor weight, I only know about my tractor. Mine may be more than 700 pounds heavier. I have the rears loaded with fluid. I 'think' it added about 400 pounds per side.
/ L3700 Bottom Plow
Thank you all for all your input. You've given me a lot to think about and figure out.
Mike
/ L3700 Bottom Plow #25
Very interesting thread. I have been thinking of getting an L3700 SU but my dealer has told me that the HST is not the best for ground engagement use. I see that the L3240 is an HST and has made some nice furrows, is it hard on a L3700SU HST to pull a plow or other ground engagement tools? beacause it is lighter? smaller? not built for it?
Thanks,
Martin
2022 EZ-GO ELITE...
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2016 Ford F-550 4x4 ETI ETC37IH 37ft. Insulated Bucket Truck (A64556)
2016 Ford F-550...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
