L3650 noise
   / L3650 noise #1
John3650
I just purchased a 1993 Kubota L3650 ,GST,4WD with a LA650 loader, it has 640 hrs on it. I have noticed when I am descending a grade I can hear a rattle type sound.
It sounds like it coming under the cover plate housing the transmission. It seems to be when you let off on the throttle while descending a grade.
I not sure what it is or if it is normal or not. Any thoughts?
Thanks,
John
   / L3650 noise
I have determined that the noise seems to be when the tractor is in 4th gear and while idling and descending a grade. When I throttle it up a bit or change to another gear I don't seem to hear it.
It just seems to be in a certain spot and it does not do it for the whole length of the hill.
John
   / L3650 noise #3
Intermitten noises like that can be a bear to track down, I wouldn't worry too much till it gets worse to where it can be tracked down easier.
GENERATOR HOUSE POEWERED BY TWIN 12.7 DETROITS (A50854)
GENERATOR HOUSE...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
Ranch Hand Pickup Truck Grill Guard (A49461)
Ranch Hand Pickup...
