RebelRider
- Joined
- Jan 3, 2021
- Messages
- 8
- Tractor
- 1993 L3650
1993 Kubota L3650 4wd with the mechanical shuttle shift. The tractor has 800 hrs on it and works great. The only issue I’m having is the clutch doesn’t seem to want to fully disengage. When I push the pedal in, the tractor stops, but there still seems to be tension pushing the tractor forward. For example, going up a hill in forward, I push the clutch in. The tractor stops, but doesn’t roll back. If I shift the column into neutral, it then rolls back down. It’s almost if the clutch is still grabbing even though the pedal is depressed. It does this in forward or reverse. I’m also getting a little grinding going into gear, surely when cold.
Hopefully this doesn’t sound too confusing, but can anyone help? Thanks
