L3600 wont steer forward
   / L3600 wont steer forward #1
vinifera
Kubota l3600
tractor will steer Backwards but not forward, pulls hard to the left in forward
belts are on, ties rods look good ..... ?
cannot find the PS fluid reservoir though, not shown in manual
update I found that it uses the same hydraulic fluid as the rest of the systems (loader and 3ph working)
and belt seems a bit lose but no seized pumps
   / L3600 wont steer forward #2
The L2900, L3300, L3600 and L4200 are all in the Same family so many of the things in any of these models will be similar or identical...
and you are right the Hydraulic/Transmission fluid is used in the steering system, You have 2 separate engine driven hydraulic pumps, one for steering and another for all other hydraulic needs.
Use your loader and lift the front of the tractor off the ground, with the engine running can you turn the wheels Full to the left and also to the right?
Then try the same thing With the engine Not running... can you turn the wheels full lock to lock? Is it approximately the same effort in both left and right?
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
2016 New Holland B95CLR Loader Backhoe (A50860)
2016 New Holland...
2012 Ford Focus Hatchback (A48082)
2012 Ford Focus...
2010 Buick Enclave CXL SUV (A48082)
2010 Buick Enclave...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
