Loader L3600 la680
   / L3600 la680 #1
deranged
Marthasville, MO
Cub Cadet 102, L3600 Kabota; 1530 John Deere
I have a leaking cylinder on my la680 and went to get the rebuild kit, but there are two different kits. I can not see markings to tell me what cylinder I have so is there any way to tell without opening the cylinder up to look at the "ram" size?
   / L3600 la680 #2
Which is leaking, a boom cylinder or a bucket cylinder? The parts diagram lists two versions each of the boom and bucket cylinders but they all use the same two seal kit part numbers, 75554-64600 and 75554-63400. If you got one of each kit you'd be sure to have the parts needed to fix the leaker.
Alternatively, take the leaking cylinder's parts to a hydraulic shop to match up the head seal and wiper. Much nicer than buying 2 whole kits and only using 2 pieces. A leaking cylinder can often be fixed cheap. The internal piston seals are most often fine and can be re-used.
   / L3600 la680
It is the bucket cylinder leaking most likely the dirt outer seal is missing a chunk. But if I was going to pull it apart I might as well get all the seals at once, I figure. I was being a tightwad and hoping I had the cheaper 20 kit instead of the 40
2012 MACK CHU613 (A50854)
2012 MACK CHU613...
2019 Generac MLTS-1 2.4kW Towable Light Tower (A49461)
2019 Generac...
2022 Club Car...
2018 Ford Explorer AWD SUV (A48082)
2018 Ford Explorer...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2018 Hyundai Sonata Sedan (A48082)
2018 Hyundai...
