I went through what you are going through in 2012, before buying my
L3560 open station in January 2013.
Buy a ten foot stick of 1-1/4" PVC pipe. Cut it to 66", the width of the
L4060. Mark it at 60", the width of the
L3560. Walk around your land to see which tractor will fit between your trees and through your gates. I work in woodland much of the time. On my land it was evident the
L3560 would fit between Oaks better. (See below.) (I plow occasionally.)
Kubota says the 4060 is about 6 inches wider and I want max stability for retrieving firewood.
All the Grand Ls have several increments of rear wheel width adjustment standard, with both R1/ag and R4/industrial tires. An unusual feature which is part of the deluxe package. Rear wheel/tire stance is the #1 factor in improving tractor stability. "Loading" rear tires 50% or 75% with liquid helps too, but not nearly as much.
With the rear wheels spread wider than the non-adjustable front wheels you lose the ability to operate moldboard plows as front and rear right-side tires have to fit in the active plow furrow.
You have not revealed your location. Above 4,000' altitude some
L3560/
L4060 owners feel a backhoe and/or cab equipped tractor is a bit short on horsepower moving up hills. (You may not be considering a cab. You may not be considering a backhoe.) Both engines are naturally aspirated. Turbos eliminate altitude power loss. Few with a cab "load" rear tires, the cab provides ample traction weight. I have never felt the need for more power in my
L3560 in relatively flat, sea-level Florida. My tires are inflated with air.
I'm considering the 4060 over the 3560 is mainly size but also for the 4 cylinder vs 3.
I do not know the basis for your preference. The three cylinder
L3560 diesel is very smooth. Fewer bits and pieces subject to wear and repair. If you need 50-55-60 horsepower it makes sense to consider four cylinders. The "4" is in all the 66" tractors for marketing consistency.
My home sits on 3 acres but I have another 30 acres at the end of the road.
You have not mentioned any farm work. If you will farm your thirty acres the
L3560 uses mostly 60" wide implements. The
L4060 uses 66" and 72" implements which means less time doing soil prep, crop cultivating and harvesting.
Be aware that neither an open station
L3560 nor an open station
L4060 will fit under an 84" garage door header without cutting the ROPS. Both are about 5" too tall. (Big surprise to me in early 2013. May be lower in 2021. )
Moving big rocks....
Order the optional LA805 Loader with the
L3560. Consider L2296 heavy-duty, round-back SSQA bucket to securely mount a Bucket Spade.
Bare tractor weight is a spec used to evaluate tractor capability.
L3560 = 3,500 pounds.
L4060 = 3,527 pounds.
102.4 KB
4.7 MB
