L3560HSTC steering wheel seems like it's spinning freely
   / L3560HSTC steering wheel seems like it's spinning freely #1
JerkyChew
shopping
This can't be a good thing - I noticed while driving my tractor that, in order to keep my front wheels straight, I had to have the wheel turned off center. A few minutes later the wheel needed to be rotated 90 degrees to stay straight. Shortly afterwords the wheel was back at top dead center to keep the wheels straight but I thought hey, that can't be good. So I shut it off and it looks like I can spin the steering wheel all the way around and the front wheels don't turn. I'm assuming that this is a problem, right? I haven't gotten under the tractor yet to poke around; since it's under a service contract I'll probably call my dealer tomorrow rather than mess with anything, unless you guys tell me that this is some fancy Kubota feature :)
Video here.
   / L3560HSTC steering wheel seems like it's spinning freely #2
Your tractor is not "mechanically" steered. More like your steering wheel is connected to an ?orbital? valve and on the axle, to a cylinder that's controlled by this valve.
That crude explanation is as far as I can "go" before I start talking chit! ;)
It's a hydraulic problem that is probably pretty simple vs worrying about a mechanical steering box.
Checking your hyd (transmission) fluid level and looking for leakage in what would be considered the steering "column" and any hydraulic lines (rubber or steel) that may go between the transmission and these 2 components.
Hopefully someone will hop on that really knows. 😆
   / L3560HSTC steering wheel seems like it's spinning freely #3
Hydraulic steering on tractors is quite different from a regular vehicle as there is no mechanical connection between the steering wheel and the actual wheels. It's all relying on the fluid.
As with anything hydraulic, there are always losses and leak down in the system as the valves rely on very close tolerances to work. Some fluid bypasses through these close tolerances and eventually you have to correct the steering wheel. Some brands are worse than others.
As far as steering valves, some still allow you to steer even with the engine off, albeit with obviously more force needed. If I recall correctly from similar discussions on older threads, Kubota doesn't have this feature in their steering valves, that's why you can just steer without moving the wheels.
They're also notorious to have way too much leak down in their valves, be it steering or remotes in the back. Honestly way too much for what they charge. This results on have to do a lot of corrections on that steering wheel just to go straight.
On my tractor, I can go miles and miles with minor corrections to the steering wheel and can turn the wheels even with the engine off.
Interesting! Thanks for that info, I wasn't aware of how this worked. I don't think I need to panic as much as I initially thought.
One issue I've had since day 1 is that when the front bucket is loaded, steering is very difficult. Increasing the RPMs obviously helps but I noticed yesterday that it seemed more difficult than normal when my bucket was loaded with dirt. I brought this up at my last service and they just shrugged and called it normal. Maybe I was just at my weight limit and it's an "it is what it is" situation.
   / L3560HSTC steering wheel seems like it's spinning freely #5
Also be sure that your front tires have maximum air pressure, this will also ease the steering issue when having a loaded bucket.
   / L3560HSTC steering wheel seems like it's spinning freely #7
always move forwards or backwards as you steer makes it easier and less tearing up the grass. My kubota can steer with the engine off but it is hard.
UNUSED IRANCH 1R EXCAVATOR RIPPER (A54757)
UNUSED IRANCH 1R...
2015 Kubota KX91-3S2 Mini Excavator (A52377)
2015 Kubota...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
Duetz Power Unit (A50120)
Duetz Power Unit...
2011 Doonan 482FBCHTTDBZ 53ft 40 Ton T/A Flatbed Equipment Trailer (A52377)
2011 Doonan...
