L3560 Kubota
/ L3560 Kubota #2
Welcome to TBN.
Have you check the fuel filter?
Are you setting in the seat?
Little more info would be helpful.
/ L3560 Kubota #3
Is the gear selector and pedal in neutral? Does pedal need adjustment?
/ L3560 Kubota #4
Had this happen on my L-series once—turned out to be air in the fuel system after a cracked fuel line let air sneak in. I'd start by checking all fuel line connections and the fuel filter and bleeding the system. Also, make sure the fuel shutoff solenoid is clicking properly—it’s an easy one to miss!
(38) 8" - 11'L X 20" - 34" FLOOR TRUSSES (A60432)
(38) 8" - 11'L X...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
skeleton / rock bucket (A56857)
skeleton / rock...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
