L3540 Hydraulic line cracked
   / L3540 Hydraulic line cracked #1
gavinfred1
Indiana
Kubota Grand L 3540 hydro
Hey all,
I have recently developed a cracked hydraulic line that seems to originate from a plug on the bottom of the tractor that weaves its way to the front of the tractor that I can't see without alot more investigating. I will post a picture later but I was reaching out to see if anyone had similar issues with some help or if I should just take it to my dealer. HELP!
   / L3540 Hydraulic line cracked #2
Does it look like just one bad section of pipe while the rest is fine or do you think the whole pipe needs to be replaced? If the pipe doesn't need replacing there's a company called Swagelok that makes a connector for tubes that doesn't require the tube to be flared. They should make both SAE and metric. They are rated for a lot higher than any pressure your tractor could develop and the vibrations shouldn't be an issue.
Thanks for the reply. I am familiar with Swagelok from work. My issue is with the hydraulic line leaving the pump (I think) to the power steering box. See attached. I am not scared to remove just not sure if I should try wiht how long the line is and the tight area.
I have removed the other end...I assume that I just remove the bolt and the line goes to the "round" fitting?
   / L3540 Hydraulic line cracked #5
I am NOT a hydraulic expert. From the experience I do I have there most likely is some holes in the bolt or a smaller thread section that allows the fluid to pass thru or around the bolt. And I suspect the round fitting is part of the line, all one piece.
   / L3540 Hydraulic line cracked #6
With having an Lxx30 series manual only, is this the Hydro Charge Pump line? If the line is cracked and leaking, why not replace it? If it has fatigue cracks starting I think they will travel down the line.
If the leaking area is the Banjo Bolt, you may need some new washers that have not been compressed.
David
   / L3540 Hydraulic line cracked #7
Can you reload the 2nd image?
The second picture was the same picture as the first. I have no problem replacing it...I just wasn't familiar with the "banjo bolt". I will try to back out the bolt tonight and remove the line and replace it. It ends up at the power steering box at the front end. I am not sure of how in the world it will come out as there isn't more than 8" of straight to it and I would guess it is 6' in total length. Would anyone recommend where to purchase the line and associsted hardware? Thanks for the replies!
   / L3540 Hydraulic line cracked #9
Are you sure the line is cracked? Or is the leak coming from one of the banjo bolt seals? As mentioned above, the banjo bolt should have a seal between the bolt head and the circular line end, and another seal between the circular line end and the tractor.
Great question. I'm not sure as it started as a drip and now I can't use the tractor because it blows out so much. I will take the bolt out and check it out and the seals. I just assumed that it was the line itself. I'm not 100% sure either way. If it was the seals that would make it a much easier fix.
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
BUSH HOG 7007 LOT NUMBER 115 (A53084)
BUSH HOG 7007 LOT...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53472)
2-Row Peanut...
