L3540 3 Point Lift Control
   / L3540 3 Point Lift Control #1
claridon
Geauga County (snow country), Ohio
Kubota L3540HST+
I知 new to this site and am really glad I found it.
I知 in a quandary right now and am looking for some of the expert advice I致e seen so much of.
I am about to purchase a new tractor and considering the Farmtrac 360DTC or the Kubota L3540. I know it痴 not quite apples to apples, but this is where I知 at.
My issue is with the 3 pt hydraulic lift control on the Kubota: 撤osition control is standard; 泥raft control is optional. I want to be able to use a 2 bottom plow. Is the optional draft control necessary or can plowing be done with the standard position control?
The Farmtrac has draft control (as well as 2 sets of remote outlets) as standard.
All the old Fords I致e owned have had draft control. I don稚 want to overlook ordering it if I really need it on the Kubota.
Thank you in advance for any insight or experience you can share.
   / L3540 3 Point Lift Control #2
I am far from an expert on anything to do with ground engaging equipment - or anything else for that matter.
However, if I were planning to use a plow, I would want draft control to control the depth.
Let me add something else for you to consider. Have you considered moving up to the L3940 or the L4240? I know that the former is not that much more than the L3540 and the extra HP might help with the ground engaging work.
Thank you for your response, I appreciate it. I've looked at the larger tractors and have decided to draw the $$$ line at the L3540. I'd love to go larger but....
Thanks.
New Holland 499 Hydra - Swing Mower Conditioner (A50514)
New Holland 499...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
LandPride RCF2072 (A50120)
LandPride RCF2072...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2009 MINI Cooper Coupe (A50324)
2009 MINI Cooper...
