Price Check L35 Price opinions?
   / L35 Price opinions?
Thanks again Mach. Since youve been quite helpful so far.......I am going to PM a link to you. It is the used equip outfit that has the L35 Im looking at. I know its tough to judge a whole lot by picture but could you look at them for me and see what you think? Thanks, Tom
   / L35 Price opinions? #12
Tom--The L-35 has seen a paint shop recently. It is missing two grill guards, the primary one you could push a dump truck with, and is externally mounted and cross braced. The secondary one, mounts at the opening of the front, just ahead of the radiator with quick disconnects for battery access, but is heavy and strong enough you could use for a drain basin on your driveway. The next question could be why, and how far did the damage extend into the engine compartment. The price of a new radiator would eat up a $500 bill easy. The sheet metal looks bent in that area as well. I am going to study the pictures and give you more thoughts, but read this message, while I look this thing over. It looks like it was a rental and they may have purchased it at a auction? Did they give you any accurate info on the prior owner to contact? I will give you more of my feelings after I study the photos more.
   / L35 Price opinions? #13
Tom---- After reviewing it for the second time, the canopy also has damage on the top and sides, but probably not a structural problem. I don't know if you are perfectionist type or not, I have a tendency to want everything to work as advertized, or buy it with the idea of making it right; but you need a starting point called the "law of diminishing returns", where it will cost you more to fix it, without increasing it's value. I believe tractor dealers, franchises, work on a limited profit margin, but when you walk in for replacement parts, you might think you are buying fine jewelry, and may need a liquid pain reliever when you return home. If that radiator starts to fail, unless a new one was installed, replacing the original grill guards, and any pins and bushings that have to be replaced, will cost a couple thousand dollars. Just a original "rattle can" of Kubota orange paint at the dealerships, will cost $10. They make money on parts and supplies in my honest opinion. There are tractor junk yards also, that may have the replacement parts, but this tractor maybe too new. It could also be in good mechanical, and the owners disreguarded the cosmetics? Before you go see it, have some numbers in your back pocket for the visual needed replacement parts, and also use it as bargaining chip after testing the tractor. Personally, I would not buy or tow a trailer that distance on a whim, and be totally disappointed. I was deceived early in life by a person embellishing an aircraft over the phone, and wouldn't hold it for me, without a moderate deposit. The A/C was in Montana and I lived in LAX. After a long and costly trip and a flight test; he was trying to sell me junk, which required a lawyer to get my refund! These are just my opinions only, and I don't want to "rain on your parade!" ---LEE
Hello Lee, well I called about the L35 today......he says the tractor was not a rental and spent its previous life as a skip loader......the backhoe was from a rental yard and is much newer (as it looks in the pictures). He said a local rental place had it sitting in its yard not attached to anything and he bought it from them for the L35. He didnt know how many hours might have been put on it. He said only one stabilizer ram seeps hyd fluid, not much according to him. Said the loader pins were about what youd think of a 2300 hour machine but surely wouldnt need to be replaced anytime soon. He also said they checked 4X4 and all hyd functions and all worked fine.......and they would change all fluid and filters (I doubt he meant coolant and hyd fluid also) as soon as it sold if it hadnt been done already. Anyway thats about what I know so far......Thanks again, Tom
   / L35 Price opinions? #15
Tom---One other point while my mind is engaged. The GST transmissions are a great asset to the tractor, which allows shifting without clutching. The down side, shifting with clutching is easy too. If the operator uses the tractor in the clutching mode, while loading dirt in the loader, and "rides the clutch", instead of selecting a lower gear; it will cause premature clutch wear. I read awhile back on this board, a Kubota mechanic said, "the life of the clutch can be as short as 1000 hours, or even less, if the clutch is abused." Check the clutch in both modes in all gears with the shift lever only for cavitation, and the manual mode for the same reason. There is a slight delay in the non clutching mode, which is normal. Have you had too much info yet?----I just want to cover the important things that are pricey to repair, and I think this is a two stage clutch also? I have never used the PTO, and I maybe wrong.
LEE
   / L35 Price opinions? #16
Tom---That sounds like good news overall. However, for your own piece of mind; it is easy to remove the side cowlings, and I wouldn't buy it till I looked into the engine compartment focused on the radiator/fan/ forward exhaust area/water pump, and etc. To destroy those grill guards, required a massive hit!! Plus the sheet metal area is a heavy gauge also. After looking at my original purchase paperwork, the primary grill guard was a $200 dollar option that I added to the tractor, SORRY, MY MISTAKE! I would still look for residual damage, since a big battery sets just forward of the radiator. It was probably purchased without the primary grill guard, which explains the damage. Another plus, the tractor hasn't eaten a lot of dust and dirt in the construction environment.-----LEE
This also explains the damage on the FOPS (FALLING OBJECTS PROTECTION STRUCTURE) with boxes and crates falling. Also, sounds like an honest dealer with legitmate answers. Starting to sound like a fair deal.
   / L35 Price opinions? #17
Tom----I will give more good news on the clutch, which is a single stage, and you can do your own wrenching when it is time to change it, since it doesn't require special tools and procedures to install. I hope things turn out good for you.---------LEE
Hey Lee thanks so much, I am going to call the guy back tomorrow to let him know if I am heading down to look it over. Thats grood news on the clutch too if it needs one. One of the things I plan to use it for is to cut the pad and dig footings for the new shop, and I have quite a tool addiction plus I enjoy turning wrenches. Also as far and the L35's apperance......I really dont care much what any of my stuff LOOKS like......but I am very **** about them being mechanically sound and reliable......In the end after all your imput I will probably head down to see the tractor and if it is not in horrible condition I will probably tow it home,......Thanks for all your time with this,,.....I have wanted a tractor for some time and I hope it works out.......Tom
   / L35 Price opinions? #19
Tom---Another fact on backhoe operation, the engine at idle is between 850-950, and will provide all the hydraulics needed for the backhoe, providing good smooth operation, if the cylinders on the hoe are good. Higher RPM will result in too fast of movement, causing bucket banging. Your fuel usage will be less than 1/2 gallon per hour for the hoe, and maybe 1 gallon/hour at max rated power, which you will probably seldom use? It seems to run for weeks on 9.2 gallons for my operations with the 100.5 cu. in. engine, that is extremely smooth. Please post the final scenario of the L-35, and any misleading info that I gave you.-------------LEE
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Ford F-550 4x4 Chipper Truck (A55973)
2012 Ford F-550...
2018 Chevrolet Silverado Service Truck, VIN # 1GC1KUEY2JF129960 (A57453)
2018 Chevrolet...
2264 (A58376)
2264 (A58376)
2007 Honda Odyssey Van (A56859)
2007 Honda Odyssey...
New/Unused Single Portable Toilet (A57453)
New/Unused Single...
