L35 key wont turn off engine
   / L35 key wont turn off engine #1
ChrisR
Henley Brook, Westen Australia
Kubota L35
Hi everyone
I just finished using my L35 and when I turned the key off, the engine didn't stop. This is the first time this has happened.
Has anyone got any ideas why? or how to fix?
Regards
Chris
   / L35 key wont turn off engine #2
The key on my B7500 isn't supposed to shut off the engine, so the best idea I have is that it sounds like you might have the opposite of the problem addressed in this thread.
Good luck!
   / L35 key wont turn off engine #3
Check the fuse, the L-35 had a problem with that fuse holder going bad/corroding. The fuse may be good but it's not making good contact. Other items in the system that may be at fault include the stop solenoid and or the time delay relay.
   / L35 key wont turn off engine #4
Yes,, exactly what Kubmech said. I had a L35 that did that until I cleaned and replace the fuses in the fuse holder located on the lower left sitting in unit. ????????? I think it's there.. /forums/images/graemlins/smile.gif Tell us how you made out.
Darin
   / L35 key wont turn off engine #5
Kubmech, after 3 months, I was wondering what happened to you. Glad to see you back.
   / L35 key wont turn off engine #6
Ditto , Birds reply. wondered what happened to u . missed your expert advise. but a question, why would a bad fuse connection STOP a machine from shutting down? would it not stop it from starting? i am as always confused /forums/images/graemlins/confused.gif and again welcome back.
Thanks very much Kubmech and DarinRay
It was as you said, a corroded fuse box connection. I stripped the whole box down and cleaned everthing, and it works a treat now.
It's so easy when you know how!!!
Thanks once again
Regards
Chris
   / L35 key wont turn off engine #8
I have a B2150 with the same problem-starts up but won't shut down with the key. Is this apt to be the same problem or something else? I don't know where the fuse box is. Any help?
   / L35 key wont turn off engine #9
Hey Guys, 'been pretty busy for the last few months, computer time and access has been pretty limited, however, I have been able to check in from time to time. Just not enough to get involved with many discussions.
Thanks for the welcome back..................
   / L35 key wont turn off engine #10
The L35 and the 2150 both operate pretty much the same way for shut down. There is a solenoid attached to the injection pump linkage. When the key is placed in the off position it energizes through a "time delay relay" and pulls the linkage to the shutoff position. The time delay holds it for a few seconds to ensure the engine shuts down then releases.
The fuse box on the 2150, if I remember correctly, is on the right side of the engine firewall. Pull the right engine panel and you should see it. Can't remember for sure which models
/options but some tractors came with just a manual shutoff lever and may not have a shutoff solenoid.
Agco 4210 3pt 2 Star Tedder (A50774)
Agco 4210 3pt 2...
International 820 Platform (A50514)
International 820...
UNUSED TOPCAT ECSSSTG200 STUMP GRINDER (A51244)
UNUSED TOPCAT...
T3 Motion Patroller Segway (A51694)
T3 Motion...
2014 Kia Sorento SUV (A50324)
2014 Kia Sorento...
Utility Trailer (A50515)
Utility Trailer...
