Oil & Fuel L35 Front Axle Lube
/ L35 Front Axle Lube #1
Kickstand
Huntersville, NC
1997 Kubota L35
I recently bought a 1997 L35 with 1270 hours. The front axle lube is low. Reading the manual, it says you can use either Kubota SUDT, UDT, or 80-90 weight gear lube. I don't know what's in it now. I'm surprised that fluids of such different viscosity are both ok. I'm leaning towards using the 80-90 weight gear lube because I see some evidence of leaking where the axle turns down toward the wheel on both sides and I figure the heavier grease will be less likely to leak. Which should I use? Should I worry about a little leakage?
Any thoughts on this subject would be greatly appreciated.
Joe
/ L35 Front Axle Lube #2
Joe
personally i agree w/you that 80/90 wt. would be the choice. by just topping off, don't think it will make a big difference in the leaking issue. i have read that many machines have a seal problem given those hrs. of course you can tell what the existing fluid is in there by the scent of 80/90. the new tractors i've owned came w/udt (or at least a thinner fluid than 80/90) and were low as well. guess the leak issue is how often you have to top off...you could always drain the ft axle (not a bad idea w/that many hrs), fill w/gear oil, then monitor. there are a # of posts on how to change the seal itself if you want to do it. good luck
2022 Seppi MINIFORST CL 175 Skid Steer Forestry Mulcher (A65640)
2022 Seppi...
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
2011 HEIL TRAILER (A65643)
2011 HEIL TRAILER...
2007 International 7300 Digger Derrick Crane Truck, VIN # 1HTWBAAN77J422035 (A65563)
2007 International...
Iranch High-End Tricycle (A64119)
Iranch High-End...
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
