Backhoe L35 Engine Oil
/ L35 Engine Oil #1
lrhall
Elmira, WV
Kubota L36
I would like a recommendation as to what kind & how much engine oil is needed for my L35 Kubota. Thanks
/ L35 Engine Oil #2
DO YOU HAVE A MANUAL ON THE TRACTOR? HAS A DEALER TOLD YOU WHAT OIL THEY RECOMMEND? I JUST POSTED A THREAD CALLED "WHAT OIL DO I USE?" AND IT WAS IN REGARDS TO MY L3200. I WOULD BET THAT YOU CAN USE THE SAME THING I DO : ROTELLA 15W-40. ITS THE MOST POPULAR OIL FROM WHAT I HAVE BEEN TOLD FOR TRACTOR DIESELS. MY DEALER RECOMMENDED 10W-40, AS DOES MY MANUAL, BUT AS LONG AS ITS A "C" RATED DEISEL OIL YOU WILL BE FINE. AS TO HOW MUCH....NOT SURE THERE, BUT MY L3200 HOLDS 6.5 QUARTS. ROTELLA IS SOLD BY THE GALLON (4 QUARTS) SO I BOUGHT TWO GALLONS AND THEN CHECKED THE DIP STICK, ADDED A LITTLE AND CHECKED AGAIN UNTIL I REACHED THE PROPER LEVEL. BEST ADVICE I CAN GIVE IS THAT IT NEEDS TO BE DEISEL OIL....THERE IS A DIFFERENCE BETWEEN DEISEL AND STANDARD MOTOR OILS. HOPE THIS HELPS.:smurf:
/ L35 Engine Oil #3
Sorry about the all-caps and underline there! by the way...Welcome to TBN!!
/ L35 Engine Oil #4
a quality diesel oil ( c rated ) in a viscosity for your temp range. that means it's likely gonna be a 15w40 or 5w40 synthetic.
/ L35 Engine Oil
Thanks, very helpful. Yes, I have an owners manual, but am away from home at the moment. Thanks again
2011 Ford Expedition SUV (A64557)
2011 Ford...
New Carbon Steel 4.75-12T Shackles, 38 Total (A62679)
New Carbon Steel...
213097 (A64276)
213097 (A64276)
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
(2) Planter Boxes (A66408)
(2) Planter Boxes...
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
