Backhoe L35 Engine Oil
   / L35 Engine Oil #1
lrhall
Elmira, WV
Kubota L36
I would like a recommendation as to what kind & how much engine oil is needed for my L35 Kubota. Thanks
   / L35 Engine Oil #2
DO YOU HAVE A MANUAL ON THE TRACTOR? HAS A DEALER TOLD YOU WHAT OIL THEY RECOMMEND? I JUST POSTED A THREAD CALLED "WHAT OIL DO I USE?" AND IT WAS IN REGARDS TO MY L3200. I WOULD BET THAT YOU CAN USE THE SAME THING I DO : ROTELLA 15W-40. ITS THE MOST POPULAR OIL FROM WHAT I HAVE BEEN TOLD FOR TRACTOR DIESELS. MY DEALER RECOMMENDED 10W-40, AS DOES MY MANUAL, BUT AS LONG AS ITS A "C" RATED DEISEL OIL YOU WILL BE FINE. AS TO HOW MUCH....NOT SURE THERE, BUT MY L3200 HOLDS 6.5 QUARTS. ROTELLA IS SOLD BY THE GALLON (4 QUARTS) SO I BOUGHT TWO GALLONS AND THEN CHECKED THE DIP STICK, ADDED A LITTLE AND CHECKED AGAIN UNTIL I REACHED THE PROPER LEVEL. BEST ADVICE I CAN GIVE IS THAT IT NEEDS TO BE DEISEL OIL....THERE IS A DIFFERENCE BETWEEN DEISEL AND STANDARD MOTOR OILS. HOPE THIS HELPS.:smurf:
   / L35 Engine Oil #3
Sorry about the all-caps and underline there! by the way...Welcome to TBN!!
   / L35 Engine Oil #4
a quality diesel oil ( c rated ) in a viscosity for your temp range. that means it's likely gonna be a 15w40 or 5w40 synthetic.
   / L35 Engine Oil
Thanks, very helpful. Yes, I have an owners manual, but am away from home at the moment. Thanks again
LOT: (4) Large Wheel Chocks (A59076)
LOT: (4) Large...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2007 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2007 Chevrolet...
2020 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2020 John Deer...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
