L35 Buckets or teeth
/ L35 Buckets or teeth #1
Anonymous Poster
Epic Contributor
Who makes aftermarket teeth for the L35 backhoe buckets? I'm looking for a more pointed or skinnier shape to better dig hard ground and rocks. Also, does anyone make buckets for same other than Kubota? Their prices are a lot hard to swallow.
/ L35 Buckets or teeth #2
The Kubota buckets I've seen, and I admit it's not a whole lot of them, are made by Gannon. The name plate says "Kubota, made by Gannon", or something to that effect. I also think the teeth are Henley (I think I got that name right, but it's stamped right on them).
You might try calling Gannon (now owned by Woods) and ask if they have buckets for the L35.
/ L35 Buckets or teeth #3
As hayden says, the buckets are made by Woods/Gannon. You are also right in that they are expensive. Mine (12") run in the $350 -$400 range for a B21 which runs smaller pins. Wait till you have to buy any new pins. I was looking for the gold plate. Let us know if you find them for less.
Thanks for your input, I'll try researching in this direction and see where it gets me.
I've checked on a 12" from CarverEquip for my L35, $565., yikes! I always found that JD parts were made of Gold, while JD and Caterpillar parts were made of a similiar material as Kubota, Titanium. I've found some parts at Carver cheaper than my local dealer and some more expensive. But I continue to shop.
No, Kubota does not use Titanium anymore, they are using pure unobtainium. I needed a hydraulic valve, through Kubota it was $370. I would like to support the dealer network, but the same Husco valve through a traditional hydraulic supplier was $96. Of course the one from Husco was only machined from cast iron.../w3tcompact/icons/smile.gif
del
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
2005 Chevrolet Silverado Service Truck, VIN # 1GCJK33245F911286 (A65563)
2005 Chevrolet...
