Buying Advice L35 Backhoe
/ L35 Backhoe #31
Three years ago, I paid $24,000 for a 2002-2003 L35 with 122 hours on it. It was in very good shape and looked like it had been kept inside for all but maybe one year. It was not a rental unit. Prior to purchase, I had looked for a long, long time before I found one in that shape.
Like a previous reply said, the L35 is a little bear. It's a real loader/backhoe and not a tractor with an add-on loader and 3 point hitch backhoe. Look at the frame under the L35 and compare that to another brand or even another Kubota that is not a designated TLB. Hmm, the others' don't have a designated frame. Also take a look at the loader and hoe buckets and compare, they're heavy duty. She's not at all fancy but she's put together like few others.
With that said, it's designed as a backhoe and not a tractor. It will work as a tractor but may not pull or function like a designated tractor. Auxilary rear hydraulics are not standard but can be added. If the unit has these, that's a big plus.
Another place to look is the tires. Are they in good shape, foam filled or loaded? Many renters foam fill the tires to prevent flats. I believe this costs about $500 to $800 and adds both weight and traction. However, there can be a down-side to foamed tires. The tires no longer have their bounce and cushion. This can subject the unit too addition stress.
Ask if you can take the operators manual when you rent it. Take the time to read it and check to see eveything works. Manuals came with it and will cost extra on ebay,etc. Like someone else mentioned, make sure the 4 wheel drive and rear differnential lock work. The rear differential lock must be engaged and work before the tractor is in 4wheel drive. I'd also ensure the POT works.
You may also want to consider asking to talk with the guy that services the eguipment. Ask what type of oil and hydraulic fluid they use and ask if you can see the service records. Check out some threads on the Kubota Forum in this site related to problems related to generic fluids vs oem fluids. Take a look at the oil and hydraulic filters before they service it. Many renters write the date and hours on the filters at each fluid change. This will give you an idea of how often the fluids are changed.
If the battery is down, it's shot. I'm not sure of the cranking amps required but I'd bet an oem or equal replacement is somewhat expensive. Make sure the glow plug light comes on when you turn the key to on and it goes back out after about 30 seconds.
If you're a equipment mechanic that's a big plus. If your not and have a friend that is, ask him to take a look at it. If you rent it on a weekend and know of an equipment mechanic, see if you might be able to hire him to come over and run it. Most mechanics I know would be willing to make a few extra bucks on the side. I know from experience, your mechanics review can be the cheapest and best investment you can make. She's probably being sold as is so check it out as best you can. Quality rental outfits are usually honest. With that said, you're buying an older unit and repair costs will scare the **** out of you!
/ L35 Backhoe #32
Just one other comment on the three point hitch unit. Someone else stated the original complete three point hitch costs about $1000. They're right! Kubota is real proud of their parts.
When I bought my L35 they couldn't find the arms. When I checked out the replacement cost and asked the seller to deduct the price, they found them!
A phone call to the previous owner will be worth both your and their time.
Someone else mentioned some after market three point hitch systems for under $200. Be careful! There's alot of cheap China made junk out there. I'm not saying this is the case but the price seems too good to be true?
A poorly made lifting arm is a bad deal just waiting to happen. We all know to keep our legs and arms back but when we're hooking up in the heat of the moment, we all foreget. $200 isn't much of a deal when a back blade tips over on your foot.
/ L35 Backhoe #33
It always amazes me how money can 'jog' a person's memory. :D
/ L35 Backhoe
WOW , good stuff ....... thanks . I hope to get a guy I go to church with to look at it , he is a Kabota mechanic . I am going to offer him dinner or something :thumbsup:. I'll use the back hoe a few times a year , the 3 pt hitch alot !! I am always using a box blade . I guess the question is how many people use the L35 as a tractor ? How does it act as a tractor ? I really only need a 4X4 loader tractor , but the backhoe would be cool !!
/ L35 Backhoe
:confused2: found a ONE owner L35 with 1800 hrs , I offered $14,000 he said he would take it , going to look at it Sat . Now I have 2 different L35s for $14,000 to compare to each other . He is sending me pics , he said it was tight and clean . He said it had some blowby , but not bad, NO smoke running . New ft tires , 40% on rear . Wish me luck !!!
/ L35 Backhoe #36
why did you offer the money up front? should have waited and made a offer once you took a look at it. :confused:
"some blow by" that doesnt sound good!
/ L35 Backhoe
Saw pics , its looks new compared to the rental , I need to know what its going to take to buy it , up front . Blow by does bother me , I am hauling trailer with me, not sure of I'll buy ?
/ L35 Backhoe #38
The L35 is a good compact tractor. The backhoe swing is a little quick, so you have to be paying attention. The three point hitch is also sensitive, but that to is manageable. I prefer it to the L39 because it is shorter and narrower. I paid 18,000 for mine with 201 hours. And the hour meter works. Look at five L35s as they become available. Find the best private owner machine with five hundred hours or less, and buy that one. After all, they do wear out. 1900 hrs with many operators, can't be the best deal. For a few dollars more per month and a good bit of patience, you can have a very good tractor. First thing you want to do is fill the rear tires. With the hoe removed, the loader can get you into trouble.
/ L35 Backhoe
My problem is that I only use a tractor a few times a year , and when on vacation . Maybe 10 hrs a year ? Guessing ? I grade driveways , and play around on 6 acres. I will use the Kubota more , because it will do more . I have to many hobbies , so $14,000 is $4000.00 MORE than I wanted to spend ( $10,000 was my MAX for a used 4x4 with loader ) . I need a nice tractor for the best money . I know a LOW hr tractor would be better , but they cost alot more . I am on a TIGHT budget . So its going to be a fair tractor with high hrs or NO tractor . Remember I am coming off a 1968 , 4x2 Ford 3000 with bald tires , few leaks, million hrs ( hr meter broken ) but it came from over seas and it was used on the streets over there, so high hrs . No brakes , no lights , needs seat ,paint,battery, it needs TLC !! My dad wants me to fix the Ford , but I do not want to spend $$$$$$ on that old of a tractor . I am going to take better care of the newer tractor I buy . Going to build a shed too. L35s are expensive $$$ on any year !
/ L35 Backhoe #40
I think your on the right track the L35 is tough and has most all the bells and whistles you will ever need. We want pictures when you get it.
KUBOTA L3901D TRACTOR (A59823)
KUBOTA L3901D...
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
2008 Sea Ray 260 Boat w T/A Boat trailer (A59231)
2008 Sea Ray 260...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
