Price Check L345DT pricing
/ L345DT pricing #1
Anonymous Poster
Epic Contributor
found an 84 L345DT ,700 hours,front loader,box scraper,front mounted snow blower, weights and chains. is 11,000 a good price ?
/ L345DT pricing #2
If the 700 hours is true, 11,000 sounds fair, especially if the snowblower and chains are in good shape.
The 345DT was a very good tractor - I ran one for about 1100 hours with very few problems. I sold it for 12k with just the loader.
These have a 4-cyl engine that runs about a month on a tank of fuel. Mine developed an oil leak at the top of the front engine cover - but it was an easy fix once I figured it out.
I'm assuming it has the kubota 1720 loader - nice unit with plenty of reach and power. (Bigger than today's loaders for 34 hp tractors)
Check the 2-stage clutch - make sure the pedal can go far enough to disengage the pto. If the drivewheels clutch is worn the pto becomes full-time until the worn clutch is replaced.
Hope this is useful. Let me know if you need any other specs for it - I kept copies. Also go to the archives of this forum where Randy Diakur and others discussed 345's
/ L345DT pricing
Thanks for the info. I talked to the seller and it has a mower also.Now he said 10,000 so i think I'll jump on it. Thanks again !
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
Mower King QA Brush Cutter (A64912)
Mower King QA...
2007 CAT 140H MOTOR GRADER (A67714)
2007 CAT 140H...
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
2011 FORD CROWN VICTORIA CAR (A66091)
2011 FORD CROWN...
