L345DT Alternator questions
   / L345DT Alternator questions #1
JWSmith
Am helping a friend work on her Kubota L345DT tractor. The alternator isn't charging, we have no service manual. I need to know the electrical configuration of the regulator so as to be able to test if the trouble is in the alternator or the regulator. I/E is the regulator an "A" circuit or a "B" circuit. I need to know how to full-field test the alternator to eliminate the regulator as the culprit.
Thanks,
Joe
   / L345DT Alternator questions #2
I have a L345 service manual with a 1-page wiring diagram in it. If you think it will help, I can scan it and e-mail it to you, or I can fax it tomorrow. It appears to be fairly simple (that's coming from someone who hasn't the faintest idea what it is telling me), so it may not have the answer you're looking for.
You can fill in your profile information with an e-mail address, or click on my name to the left and send me a Private Message (PM) with your e-mail address or fax #. The file will be too large to post as an attachment.
Edit - I scanned it and used Irfanview to reduce it. Let's see if it's readable. Let me know if you need a bigger copy. Hope it helps.
Bill,
Thank you for the schematic, it came through ok. It gives me a starting point now, I just need to determine where the regulator is grounded, I should be able to do that with an ohm meter. Once again, thanks for the quick reply.
Joe
   / L345DT Alternator questions #4
Joe, I thought I'd mention that when I had my L345 I thought the alternator wasn't working. My battery was going down even though I was using the tractor. But a lot of the time it was just idling. The engine has to be spinning up at 1200 or 1500 rpm for it to kick in. I was expecting it to be more like a car where it charges as soon as you get above idle. I remember doing some kind of a light bulb test described in the manual - once I revved it up enough, presto !
   / L345DT Alternator questions #5
Thanks for posting the circuit diagram
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A52472)
2021 ALLMAND BROS...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
