L345DT 1982 hydraulic problem
/ L345DT 1982 hydraulic problem #1
BOB -TRACTOR
KUBOTA L345DT
I have a hydraulic problem with my 1982 L345 DT. The pump is almost no longer building pressure, and is no longer available anywhere. Is there a way to replace the hydraulic system with a 12 Volt electrical and hydraulic system which will do both functions (for 2 independent cylinders) of the front shovel? Which should be located on the right wing.
THANKS
/ L345DT 1982 hydraulic problem #2
Go with belt driven or find a good hydraulic shop they will get you a pump
/ L345DT 1982 hydraulic problem #3
Was it driven off the front pulley, as an agter market add-on, or a factory pump? Reason I ask, I find used Kubota pumps for $540, or new after market starting around $525. Honestly, I dont see any kinda electric driven pump being satisfactory, and probably not cheaper.
Have you A: confirmed the pump is shot?
B: taken it to a hydralic shop to see about getting it rebuilt?
It looks like all of the internal parts are readily available at Messicks; if you have the ability (or can find someone) who can rebuild it.
/ L345DT 1982 hydraulic problem #5
Have you checked your low pressure side, and screen filter for blockages; Or air intrusion? If your pump is able to draw any air, you may not see the leak, but that will give you the appearance of a shot pump (also will lead to a shot pump if you run it starved of fluid).
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A64553)
2023 Caterpillar...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
New/Unused Fuel Delivery Tank with Pump (A65583)
New/Unused Fuel...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
