L3450 work lights
   / L3450 work lights #1
L3450
Bronze Member
1992 Kubota L3450
Need some advice on wiring /switch for rear work lights . Previous owner installed lights on ROPS and connected to exsisting wires on rear fenders .
Lights work fine but draw power as soon as the key is either turned on or turned to glow plug position.
I'm no mechanic and wiring is a challenge so i'd very much appreciate some advice on how to properly install a switch into the circuit .
As the lights work fine and have now for a year would i be safe mounting a switch in a
pre-exsisting hole (factory plugged) on the left side of the dash and inserting the switch into the circuit between the power source and the (2) added work lights ?
   / L3450 work lights #2
Sure - that would work fine. It would let you turn them off for starting or running the glow plugs.
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
2020 Caterpillar 302.7D Mini Excavator (A51242)
2020 Caterpillar...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
