L3430HSTC AC recharge
   / L3430HSTC AC recharge #1
rpraymond
Madison Co., central NY
Kubota L3430HSTC, Kubota B2320 w/FEL, Allis-Chalmers D10
I have a 2006 L3430 HSTC that the AC works but isn't as cold as it once was. Are the fittings the same as on a 2006 vehicle and is the same refrigerant?
   / L3430HSTC AC recharge #2
It should be R134a.
Is the condenser clean and the belt tight?
   / L3430HSTC AC recharge #3
Fittings and refrigerant are the same... But like 94BULLITT said, check the condenser & radiator... just a small restriction to the airflow through the radiator will keep the AC system from working at peak efficiency. KennyV
   / L3430HSTC AC recharge #4
We had to clean junk out of the unit in the roof and recharge the system on our L5030 and as others have said keep the radiator condenser clean with belts in spec. There is a sight galss in the front you should be able to check for bubbles. I believe there is an old thread by 5030 on the AC improvements he made.
2003 INTERNATIONAL 9900I (INOPERABLE) (A58214)
2003 INTERNATIONAL...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
2003 Big Tex 10PI...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
