L3400 Rear Remote
   / L3400 Rear Remote #1
kubota2234
Taylorsville, NC
2008 Kubota L3400 4x4 , 1992 Ford 1710, 2003 Ford F-250 4x4, 1993 Ford F350 4x4 Dump truck, 2005 20ft Hudson brothers trailer, 1996 Hoop 16' trailer
When it comes to hydraulics I am an idiot. I want to add 1 remote to the rear of my tractor. If I put a "T" in the inlet line and return line that goes to my Front end loader block, can i run these two lines to the rear to control a Hydraulic top link? I only need it for when i operate a BB? Other than controling the bb i need it for nothing else. I know that I willl have to put a controler for the rear but would this hurt anything? I have a 2008 kubota L-3400. Questions, Comments or Rude Remarks Wanted!!!!!!!!!!!
   / L3400 Rear Remote #2
Look at your loader valve for the "PB" port - power beyond. It is now attached to the hose that feeds the top cover and supplies the hitch and ultimately it goes back to tank.
Remove the hose and have a hose made to feed your open center valve for top n tilt or whatever you want to use it for. Take the return from your TNT valve and attach it to the point where you detached the hose to your top cover.
If you want to make it so you can quickly change, make the connection to the new valve with a male and female quick coupler. Be sure when running without any other hydrualic valves that the hoses are connected to each other or the pump will be deadheaded and blow.
The system relief is under the cover and will protect your new circuit as well.
Good luck!
   / L3400 Rear Remote #3
Please stop posting your questions across 3 different forums! It makes it to hard to help you.
   / L3400 Rear Remote #4
just do a search for l3400 top n tilt and you'll have more info than you'll know what to do w/ :)
j
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
43016 (A51691)
43016 (A51691)
