L3400 question
/ L3400 question #1
blkdak
Bradford Co. Pa
Kubota L3400
The throttle lever goes extremely hard on my L3400. Are any other L3400 owners experiencing this problem? Does anybody know of a fix?
/ L3400 question #2
My L3400 is the same way, but then, so is My Ford 1910.
I think you can adjust the friction nut but I have not tried it. Take a look under there. I assume they make it hard so you don't bump it or it does not vibrate to a different setting.
I guess I'm so used to the Ford throttle lever that I never even though about the L3400. /forums/images/graemlins/smirk.gif
/ L3400 question #3
It's always hard to quantify what "extremely hard" is from one person to another, but mine has seemed a bit stiff, too. And since I'm too lazy to try and adjust it /forums/images/graemlins/grin.gif, I just live with it. I only have to use it two or three times per seat session anyway.
/ L3400 question #4
I agree..I wouldn't call it extremely hard, but it is quite stiff. I figure also that its this way so that it doesn't vibrate out of position or get bumped easily. Only time I ever use it is when running the PTO, otherwise I use the foot throttle. Its got me thinking though...there must be a tension adjustment of some sort on it, I'll have to check it out.
...Tony
/ L3400 question #5
Yeah, it's a bit stiff, but if looser I expect it might not "hold" with the diesel vibration, rough terrain, etc.
/ L3400 question #6
The friction control is straight below the throttle lever and two 12mm wrenches will fix it right up to your taste. I adjusted mine several weeks ago, I was always bumping it too much or not enough.
/ L3400 question #7
Thanks Wushaw...I had a feeling someone would chime in on this before I had a chance to look!! /forums/images/graemlins/wink.gif
...Tony
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
Bobcat 60� Tine Rake (A64047)
Bobcat 60� Tine...
2014 GMC Yukon SUV (A61574)
2014 GMC Yukon SUV...
Kuhn FC400RG (A60462)
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
