L3400 or L4400
   / L3400 or L4400 #1
fusses67
Hi all,
Just got some quots on both the kubota l3400 with fel, also l4400 with fel also, was seriously planning on the l3400, then a new quote was e-mailed on the the l4400, which was only 2k more than l3400..as the l3400 would suit my application fine, but i guess for that little bit extra $$ would it be worth its bigger brother... your thought appreciated:)
   / L3400 or L4400 #2
What is the main use of the tractor? If you don't need the lighter machine then extra hp is always useful.
   / L3400 or L4400 #3
Greetings
You never stated quotes.Also are these HYDRO'S/DT'S ?
I have 2007 l3400dt w-fel,paid $15,300 otd (new) in SW Fla.Also in every region of USA prices will vary.
Boone
   / L3400 or L4400 #4
I've got the 3400 DT as well.. it's been a great machine for me. I'd recommend trying both, the 4400 should be a little smoother with the extra cylinder.
If space is a consideration, the 3400 is quite a bit smaller frame, may be a better fit in tight spots or your garage if that's a concern. I'm glad I got the 3400 for that reason, but I'd do the same thing again even if it wasn't.
The wider rear tires on the 4400 will give you better flotation on soft ground.
Sean
   / L3400 or L4400 #5
I wish I'd gotten a quote on the L4400 when I bought my L3400. If it were only 2K more, I would have one now.
I think the L4400 PTO is a better system. More lift capacity on the FEL, and a smoother 3PH valve too.
   / L3400 or L4400 #6
I sure like my L4400HST
   / L3400 or L4400 #7
When I was buying the difference was about $5000, too much for me to swallow.
Sean
   / L3400 or L4400 #8
I'd say if you are even entertaining the idea of the 4400 then you should get it.
If their is a particular reason you need something smaller and nimble like the 3400, (such as mowing lawn regulary, tight areas, etc) then you wouldn't even be considering the 4400 in the first place.
If the 3400 can do everything you want, the 4400 can do it, just a little faster. If it isn't going to be TOO big, then go for it.
   / L3400 or L4400
Hi Again,
I just signed up, and its for the l4400 FEL, got it for $29,000 aud, as im in Australia, and squeezed a carry all out of them as well in the cost. Its just starting to sink in, as im very excited. the size difference isnt really important, its still not a full size tractor i guess, but it will have more power than i prop will ever need, can post pics but you prob know what they look like anyway. thanks for all your thoughts, cant wait prob get it in three or four days :)
   / L3400 or L4400 #10
Posting pictures is still a must:licking:
congrats on the purchase, you wont be disappointed with your kubota:thumbsup:
2011 CATERPILLAR 12M MOTORGRADER (A51246)
2011 CATERPILLAR...
UNUSED CFG QK16R EXCAVATOR (A51247)
UNUSED CFG QK16R...
2005 CATERPILLAR 321C LCR EXCAVATOR (A51246)
2005 CATERPILLAR...
2016 CANYCOM SC75 STAND ON DUMP BUGGY (A51246)
2016 CANYCOM SC75...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
