L3400 or L3800
   / L3400 or L3800 #11
At one time I thought the L3800's loader was about 100 lbs stronger, but now I am not so sure, I think it is the same, just rated in a different way.
James K0UA
The loaders are indeed the same.
The specs are newr identical.
................lift @ pins............Lift @ bucket center.......lift @ edge......BO
LA 463........1144.....................1014............................853...........1858
LA524.........1131.......................NA.............................855...........1874
As typical with the kubota loaders, the model # of the loader is its lift capacity in kilograms, substituting the last # for a 0. The last # is the "version" of that loader.
Example, the LA463 has a lift of 460kg and is the 3rd version. The LA524 has a lift of 520kg and is the 4th version.
The higher # comes from "where" they rated it at. The 463 was bucket center. 1014lbs/2.2= 460kg
The LA524 was @ the pins. 1131lbs/2.2=520kg
2017 Ford F-250 Ext. Cab Pickup Truck (A55788)
2017 Ford F-250...
16' Cattle Guard (A53316)
16' Cattle Guard...
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
2019 MDB FM180 FINISHING MOWER (A51247)
2019 MDB FM180...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
