Oil & Fuel l3400 oil change
   / l3400 oil change #1
ht1
Vestal,NY
L3400,JD 325,AC model B 1935
Oil change question on l3400. I drained all of the old oil opening the 2 drain plugs and removed old filter and installed a new filter. The book said 6qrts with filter. I used 6 qrts exactly but the oil level is an inch over the top fill mark???I am positive I drained all the old oil I let it drain for 10 min caps open ect..
   / l3400 oil change #2
Same thing happened to me the first time.
I drained some out, I always go by the dipstick. Second thought was, either there is still oil in there somewhere or 6 quarts is nominal. Never gave it a third thought.
   / l3400 oil change #3
Did you start the tractor after you poured the oil in? The new filter will retain some..
I'd like to tell you the same thing happened to me, but.... I was out in the garage making some "shelves" for my wife & going back & forth to the tractor. I left one drain plug out & dropped nearly a gallon on the floor. When all said & done, I used the remainder of the 2nd gallon of Shell Rotella & the level was perfect.
What a gooey mess new oil makes. :(
   / l3400 oil change #4
I just thought of one more point... With two drain pans, it might be possible that the one that has the dipstick in it might get a better shot of the new oil as you pour it in. You'll probably get a better reading after running the tractor a few minutes & checking again... Just a thought...
   / l3400 oil change
thanks i will drain some oil.
   / l3400 oil change #6
My L3400 came that way from the dealer. Just overfull. Maybe they just put in six and never checked it. Brian
   / l3400 oil change #7
Interesting...
When I had my 50 hour service done, the oil level was above the top notch. I assumed that the dealer new what he was doing so I left it that way. However, after moving about 6 yards of topsoil I noticed soot on my loader by the exhaust. I drained some oil to lower it to the top notch. I mentioned it to the dealer and I was told they put in what was specified. I thought maybe some oil was not completely drained as well.
I will be changing my oil at the 100 hour mark shortly. I notice the manual says the filter does not need to be changed. Do most igmore the manual and change the filter as well?
   / l3400 oil change #9
I change filter and oil at 50 hrs regardless. I'm only putting 50-60 hrs per year on my machine so that is a no brainer for me. Filter is easy to change while I am waiting for the oil to drain out and the cost is minimal.
   / l3400 oil change #10
I go by the dipsticks, and it seems every Kubota I have owned, from L2350s to L48s to KX121 excavators have never been "on the money" what the manual says. Filters are cheap in the broad scheme of things so I replace them as well.
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
Case IH Farmall 105C Tractor (A50514)
Case IH Farmall...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
2022 Polaris General 1000XP UTV (A50514)
2022 Polaris...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
2016 Ford Explorer...
