L3400 in cold weather
   / L3400 in cold weather #1
southga
South Georgia
Kubota L3400 w/FEL
What do I need to know? I am a new tractor owner. Is there anything special to keep in mind with this diesel when the temp drops? starting in cold weather?
   / L3400 in cold weather #2
How cold is So. Ga.? Diesel will "gel" up but I'm not sure how cold it needs to get. There is additives to prevent that. I just preheat to 10 secs. and it fires off with no problems in Va. mountains.
   / L3400 in cold weather #3
I wouldn't think being South Georgia you would need anything special. Up here I plug in the block heater if it is below 20f. I also run power service to prevent gelling. Above 20f I preheat for about 10 sec like TEG said and it starts right up.
   / L3400 in cold weather #4
If you are tifton area, not much but what teg said
If macon or farther north, and based on the temp, you may need to let it run to warm up some before running it hard....
2016 GMC 2500HD SERVICE TRUCK (A51406)
2016 GMC 2500HD...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
Black Galvanized Steel Fencing Kit (A53424)
Black Galvanized...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
2012 John Deere Z925A 60in Zero Turn Commercial Mower (A52377)
2012 John Deere...
