L3400 HST Pedal adjustment?
   / L3400 HST Pedal adjustment? #1
RadarTech
Elite Member
North Carolina
2007 Kubota L3400, YANMAR YT359C
Hey folks,
I have a bit of a weird one here..
not sure how it happened, but after a long day of digging the HST pedal bolts grew loose.
and the factory adjustment is not there now.
After reading the owner's guide it says not to adjust the bolt on the floor, so I would assume there must be some setting for the foot pedal too.
Does anyone have guidance on how to make sure I get the pedal settings right?
Thanks,
Jim
   / L3400 HST Pedal adjustment? #2
Jim, check to see if the petal is out of adjustment by looking for paint or wear on the metal to see if you can center it before tightening. Most hardware will tell you where it needs to be with out getting to technical. If the petal comes back to center and feels right with just moving it back and tightening don't worry about it.
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A51222)
2013 FREIGHTLINER...
Kubota RTV500 (A47384)
2015 Freightliner Cab & Chassis (A47384)
2015 Freightliner...
2013 AMSIG S/A Solar Towable Message Board (A50322)
2013 AMSIG S/A...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
