Oil & Fuel L3400 Diesel Noise
   / L3400 Diesel Noise #1
westbrooklawn
Platinum Member
North Carolina
kubota L3400HST
O.K., I'm ot sure if I have a problem or if I am just paranoid. I have an L3400 that I bought new and it has 95 hours on it. The diesel engine always seemed to have a loud tapping sound, but I just assumed that was the typical diesel engine sound.
I borrowed a friends JD 790 to use his aeravator, and it seemed to run much quieter... almost purred!! Now I get back on my L3400 and it sounds MUCH louder than I remember it being. Is this normal? Would a cetane booster help? Any ideas?
   / L3400 Diesel Noise #2
I would start there. Every engine has sounds that are unique to the design of it. Not knowing what you are hearing or concerned about I'd go to a dealers lot and ask if you could here one run.
   / L3400 Diesel Noise #3
Now you know, GREEN IS MEAN and orange is a rattle bucket:p . Take it easy just a joke..You might check your valve lash but with those low hours I would be surprised if they were out. Does your tractor have full side panels that cover the engine? That could make a diff. in the noise.
   / L3400 Diesel Noise #4
Hard to tell without hearing it. Not all diesels sound the same though.
My L3400HST is fairly quiet but at idle with the clutch engaged there is a rattle that come from the hydrostatic drive.
My 1910 is very loud. It really rattles and always has.
My little JD 748 sounds more like a gas engine than diesel.
Why not go to a dealer and have him run a new L3400 and see it yours sounds noticable louder.
   / L3400 Diesel Noise #5
I dunno - last week I test drove a brand new L3400 and it purred like a kitten - no tapping. You might want to have it checked out to be on the safe side.
   / L3400 Diesel Noise #6
My L3400 taps a little at the first time I start it up during the day. It only lasts about 5 to 10 secs though. Could be just that the oil is all down in the pan and hasn't circulated up through the motor yet.
207010 (A55853)
207010 (A55853)
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2016 JOHN DEERE 310SL BACKHOE (A52709)
2016 JOHN DEERE...
