L3400 cab/work lights
/ L3400 cab/work lights #1
jenrow33
Michigan
Kubota L3400HST
I have a L3400 and am looking at cab options. Any suggestions and/or feedback? Also, it appears my tractor has holes and wiring near the hazard lights on the fenders for rear work lights. Anyone know if this is what these holes are for?
Thanks,
Matt
/ L3400 cab/work lights #2
I just put work lights on my L4400 and the holes were too close to the hazard lights for the work lights. They were perfect for the switches tho as they are right by the existing work light wires.
/ L3400 cab/work lights #3
Yes, the holes in the rear fenders are for work lights. The extra wiring under the fenders goes to the "work light" circuit in the fuse box. Alkabo is right, rectangular work lights were too close to the hazard lights to fit properly on mine. Small circular lights would probably be okay, I mounted a piece of angle iron across the rear fenders in the existing holes to mount a larger light.
Chilly
/ L3400 cab/work lights #4
I put the rectangular light on top of my ROP attached with a rectangular u-bolt. I ran the wire through the hole and tywrapped the wire to the ROP.
/ L3400 cab/work lights #5
The worklight circuit on the L3400 is a fairly low capacity circuit. The wire is pretty light weight. I added 4 worklights - 2 front, 2 rear. To do this, I added a new 30A circuit with a fuse at the battery and ran new wires with the factory harness.
I think if all you are doing is adding the factory worklight - I think that is 30w x 2 then you are going to be fine with the existing circuit. I would recommend upgrading if you are going to go for anything more than that.
Thanks for all the light info. I'd like to see what the factory lights look like too.
Anyone have a cab on a 3400?
MJ
2012 CHEVROLET SILVERADO 1500 (INOPERABLE) (A67714)
2012 CHEVROLET...
2015 Peterbilt 320 Roll-Off Truck (A66736)
2015 Peterbilt 320...
2009 CHEVROLET IMPALA CAR (A66091)
2009 CHEVROLET...
Kohler FKHXL 2.48 TCR Kohler Engine (A64912)
Kohler FKHXL 2.48...
LINCOLN ARC WELDER (A67714)
LINCOLN ARC WELDER...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
