L3301 HST will not start
   / L3301 HST will not start #1
marksmand
woodstock NY
Kubota L3301
Got off the tractor this morning after shutting it off. Got back on and went to restart...engine not turning over.
Dash lit up and I hear the fuel pump. Checked the usual suspects/continuity in the seat switch and PTO switch and felt around the HST pedal switch and that seemed ok. Battery fine All fuses seem ok. No error codes on the dash
Any thoughts? Nearest dealer is 1.5hrs away so a service call would be a fortune
   / L3301 HST will not start #2
Did you push in the clutch? That's my normal oversight. You seem to know if the engine won't try to turn over it's probably an unhappy safety switch somewhere.
   / L3301 HST will not start #3
By pass all the safety switches by jumping from battery terminal on starter to ignition terminal on starter.
CAUTION: if the hst is not in neutral, the tractor will move and you could be in danger of being ran over.
If starter engages, you know it is in your ignition switch somewhere, ignition switch not getting power or safety switches.
   / L3301 HST will not start #4
I've seen 2 tractors with that exact symptom that turned out to be a corroded pin/socket at the ECU / wiring harness connection.
   / L3301 HST will not start #5
Should have bought the manual shift, then you could just push start it. haha... Just kidding
Ok...where is that located so I can check it out
will check out in the AM Thanks Rob
So I got it started. Did a final check on all safety switches ..all ok. Slipped tractor in neutral, put on the parking brake and while I was in the seat I had a friend activate the starter solenoid. Tractor turned over so I turned on the ignition and it started right up. It then stalled when I got out of the seat, which it should not do unless tractor is in motion or PTO is engaged.
Started up again and drove it a short way home. It is now fine and operates normally. I can't say that I have a lot of confidence in the machine now, but I will use it around the property and see how it does.
I have been in touch with Marshall Machinery through all this and they say they have no idea what might of happened except maybe something was loose etc. Will hope for the best...
Any thoughts? Rob
   / L3301 HST will not start #10
Sounds like a sticky seat neutral safety switch. It may give no troubles for many many cycles or act up tomorrow.
You did the text I recommended. You learned the issue is in a safety switch (no real surprise).
again a CAUTION! They are safety switches, you can by pass them. Unplug the switch in question and jump the wiring harness contacts. If the issue goes away, then you know which to replace. Remember the safety feature is disabled while by passed!
2018 Terex RL4 4000W Towable Light Tower (A49461)
2018 Terex RL4...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
2011 MACK GRANITE HOT OIL (A50854)
2011 MACK GRANITE...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
