L3301 dies but restarts FIXED
   / L3301 dies but restarts FIXED #1
lennyzx11
Bennington Vermont
Kubota L3301 HST/LA525 & 1964 Ford 2000 gas
Short version seat switch harness connector was loose.
Long version.
The Warranty ran out last month on my 2015 and of course last week my 3301 started dying on a sudden bump or swing of the seat with me in it.
I immediately suspected the seat switch or the PTO switch.
I had bent the seat tab down the first days I had it and upon checking, it appeared normal.
It started getting worse today till it forced me to fix it.
I ziptied the switch down but it still did it!
Hmmm.... I reached down under the seat to check my zip tie work but it was still good, (not that I ever had a doubt of course)
I checked the PTO switch and then resigned myself to go and get the multimeter and quick screwing off.
Upon wiggling, tugging, and twisting test (this is a VERY scientific procedure) I noticed the connector sliding out slightly.
Shoved her back in, made sure the lock tab was latched and good to go!
Funny part, I know for a fact that seat connector has never been touched. I do my own services and the only Warranty work was on the steering wheel bushing and I bird dogged the guy when he did it.
Tractor is always in garage also and never been loaned.
But that connector had definitely worked its way loose so don't bypass the simple stuff when your checking a gremlin.
   / L3301 dies but restarts FIXED #3
Good write up... will keep in mind.
   / L3301 dies but restarts FIXED #4
That is great to know. You didn't even have to wash any diesel juice off your hands!! :D
   / L3301 dies but restarts FIXED #5
Intermittent's are some of the hardest things to fix, and sometimes they are almost impossible to explain how it got that way.
   / L3301 dies but restarts FIXED #6
Most manufactures have a wiggle test as part of the electrical diagnostic procedure.
You just found out why!
   / L3301 dies but restarts FIXED #7
Thanks for the update..
A couple drops of Super glue autta take care of that.??
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
20711 (A50323)
20711 (A50323)
EXCAVATOR ATTACHMENT (A52472)
EXCAVATOR...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
