L3240HST Cruise lever vs HST Pedal
   / L3240HST Cruise lever vs HST Pedal #1
botayota
CT River Valley - NH
Kubota L3240Hst
With HST transmission,
Can someone explain to me why if I have Autothrottle on the engine revs up more when using the HST peddle versus using the Cruise control lever?
Thanks,
BY
   / L3240HST Cruise lever vs HST Pedal #2
Your cruise control is only controling the speed of the tractor not the engine. You control the engine rpm with the throttle lever for cruise.
mmmmm:confused:
So the foot peddle doesn't have much to do with the speed of the tractor?
Guess I better read my manual some more to understand these concepts better
:eek:
BY
   / L3240HST Cruise lever vs HST Pedal #4
botayota said:
mmmmm:confused:
:eek:
BY
The foot pedal with auto throttle on DOES BOTH. The more you push the faster the engine speed and the faster the hydro speed. Otherwise with auto turned off the foot pedal works like the cruise handle.
   / L3240HST Cruise lever vs HST Pedal #5
Greetings,
TalonDancer's Grand L 40s - HST Plus thread does an an excellent job of covering this feature.
Rik
   / L3240HST Cruise lever vs HST Pedal #6
I have a L3240HST, FEL with 6' RFM. Also box blade, landscape rake, Fergueson reseeder, forks (which I used yesterday to unload a refrigerator off my truck) and a fertilizer spreader. I now have 17hours on it. I previously owned a B7800 with these attachments. It has been a learning curve with the auto HST, using cruise, auto throttle and auto hst. I've discovered that there is not one best for all. The auto throttle is great for FEL work but I disengage it when moving the load to the dump site. Mowing I set it to auto hst and set rpms to 2700 and then drop it down to turtle by hand when it starts slowing at the crest of my hill. I usually operate in low because of my hillside and rougher terrain. Like using cruise only when driving across from one side of property to the other side with rpms around 2000. Wasn't to satisfied with my trade until I tried the different combos for the different jobs. Guess I learn better by trying than reading. Good thing is HST shouldn't tear up while your trying what works best for you for each job. Again, I have hillside with ditches and rougher yard. I use most of my attachments from time to time. Get out there and try the different combos and see by experience which works best for you.
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A52748)
UNVERFERTH 330 -...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
