L3240 Loose steering
/ L3240 Loose steering #22
Thanks David. I'll look this wknd. Is there a way to adjust?
The center seal is inside the steering cylinder, you have one at each end that seals the rod so you do not have external leakage, the center seal seals the piston against the cylinder walls and when it wears it allows fluid to flow between the left and right sides. Kubota has a rebuild kit for the entire cylinder but if a good hydraulic shop is in the area they could have the seals needed.
David
