L3240 Hyd ?
/ L3240 Hyd ? #1
PSDStu
Platinum Member
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
I am getting ready to pickup my 2wd L3240 without a loader.
I was wondering if there was anyway to use the factory plumbed loader connections and loader control stick for a set of rear remotes for Hyd Top and Tilt?
Stu
/ L3240 Hyd ? #2
You will just have to run the hoses to the rear to make your connection.
/ L3240 Hyd ?
Thanks Art!
Does it matter which of the 4 hose fittings you connect to?
Stu
/ L3240 Hyd ? #4
I can't remember the colors exactly but to cheat a little I think you will want to use the up and down for the top link and to move the lever forward and back will make those lines come live with pressure and you should be able to feel that!
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2000 LINCOLN TOWNSCAR (A64278)
2000 LINCOLN...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
KUBOTA L5030 TRACTOR (A65054)
KUBOTA L5030...
