Tractor Sizing L3240 Cab vs L5240 Cab Size Question.
   / L3240 Cab vs L5240 Cab Size Question. #1
PSDStu
Platinum Member
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
Dealer has a L5240 Cab on the lot along with L3240 No-Cab.
I was wondering if the L5240 Cab tractor is the same size as L3240 Cab tractor?
Another words other then the Loader Size when I am looking at the L5240 Cab..... am I also essentially looking at a L3240 Cab version?
Thanks
   / L3240 Cab vs L5240 Cab Size Question. #2
You've seen both side by side, so I'm guessing you are asking about total cab height?
My L5240 Cab W/R-4's is 94" tall. If memory serves me correct, the L3540 cab was 85" total height.
   / L3240 Cab vs L5240 Cab Size Question. #3
I think the smallest three Grand Ls are about 6" less in height, width, and length. they may even have slightly smaller tires but I'm not sure.
   / L3240 Cab vs L5240 Cab Size Question. #4
The 3240 will be shorter in lenght because of only being 3 cyl as 4 cyl on the 5240. I realize that the cab does not cover the engine be there will be a different in length.
2021 Takeuchi TL12V2 Skid Steer (A51242)
2021 Takeuchi...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
2019 Bobcat T770 Two Speed Compact Track Loader Skid Steer (A50322)
2019 Bobcat T770...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A51222)
2019 BIG TEX...
International 133 6 Row Cultivator (A50514)
International 133...
