Tractor Sizing L3240 Cab vs L5240 Cab Size Question.
   / L3240 Cab vs L5240 Cab Size Question. #1
PSDStu
Platinum Member
Marianna, FL
Kubota, M7060 HDC12, L4060 HSTC, RTV 1140
Dealer has a L5240 Cab on the lot along with L3240 No-Cab.
I was wondering if the L5240 Cab tractor is the same size as L3240 Cab tractor?
Another words other then the Loader Size when I am looking at the L5240 Cab..... am I also essentially looking at a L3240 Cab version?
   / L3240 Cab vs L5240 Cab Size Question. #2
You've seen both side by side, so I'm guessing you are asking about total cab height?
My L5240 Cab W/R-4's is 94" tall. If memory serves me correct, the L3540 cab was 85" total height.
   / L3240 Cab vs L5240 Cab Size Question. #3
I think the smallest three Grand Ls are about 6" less in height, width, and length. they may even have slightly smaller tires but I'm not sure.
   / L3240 Cab vs L5240 Cab Size Question. #4
The 3240 will be shorter in lenght because of only being 3 cyl as 4 cyl on the 5240. I realize that the cab does not cover the engine be there will be a different in length.
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
2016 ROADTEC RP-190E ASPHALT PAVER (A51222)
2016 ROADTEC...
2011 CATERPILLAR M318D MOBILE EXCAVATOR (A51242)
2011 CATERPILLAR...
TEST BID LOT (A50774)
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
