L3240 block heater installation
   / L3240 block heater installation #1
lockman4288
Wiscasset,ME
3240 HST TLB cab
Was looking at purchasing a block heater for the tractor how easy are they to install and where on my tractor dose it install just need some general instructions on how to do it talked with kubota dealer yesterday and they said they had them in stock so looking to do this over the holiday thanks for your help
   / L3240 block heater installation #2
Not sure if it has changed but on the L3130 that is the previous model it was just forward of the starter on the left hand side freeze plug. Drained radiator into bucket, knocked freeze plug loose with hit from screwdriver making sure it did not go in, put thread locker on the heater and drove in with hammer and socket refilled.
David Kb7uns
   / L3240 block heater installation #3
I've been thinking about adding a block heater to my 5240. If anyone has pictures of the location of the heater in the block that would be great.
   / L3240 block heater installation #5
The block heater for the L3240 goes on the left side of the engine. The heater for the L5240 goes on the right hand side. See the attached instructions.
  • Block heater.pdf
Is the instructions for the l3240 I don't see it attached that would be awesome if you have them
Thanks
   / L3240 block heater installation #7
Hi Lockman,
Not sure why you are not seeing the instructions. They show up as an attachment on my screen and I was able to download them from the post. The instruction sheet covers eight zillion Kubotas, including the L3240.
   / L3240 block heater installation #8
It doesn't show up as an attachment for me either.
   / L3240 block heater installation #10
Ok that's my issue then. Thanks
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2012 LINDE H80D FORKLIFT (A50854)
2012 LINDE H80D...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
PALLET OF PICK BUMPERS (A50854)
PALLET OF PICK...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
